[OpenLayers-Dev] status of translation possibilities
Dan Little
danlittle at yahoo.com
Thu Oct 18 10:10:10 EDT 2007
I wouldn't think this to be too hard.
In most internationalized applications I've seen, there is typically a "lang" or "strings" file that contains all of the strings for a given application. Then when the code needs a string it will call a global variable containing that error/warning/info message. This way all of the needed translation is isolated to a single file. Changing languages becomes a matter of loading an alternate language file.
So there could be a collection of language files:
strings.en.js
strings.es.js
strings.fr.js
strnigs.de.js
And then provide some basic facilities for switching between them. In fact, each of those files could be a JSON object that gets loaded to a global object/variable.
I may be just spewing bad ideas... but so long as the creative juices were flowing I'd thought I'd share.
-Duck
----- Original Message ----
To: Bart van den Eijnden (OSGIS) <bartvde at osgis.nl>
Cc: "dev at openlayers" <dev at openlayers.org>
Sent: Thursday, October 18, 2007 8:58:42 AM
Subject: Re: [OpenLayers-Dev] status of translation possibilities
Bart van den Eijnden (OSGIS) píše v Čt 18. 10. 2007 v 15:44 +0200:
> Hi Chris,
> I think it is acceptable to have a global setting. I can't imagine a
> common use case (for myself) where one map would be in English and
> another one in Dutch on the same page. It is important though that it
is
> possible to switch languages.
+1
jachym
> Best regards,
> Bart
> Christopher Schmidt schreef:
> > On Thu, Oct 18, 2007 at 03:23:50PM +0200, Jachym Cepicky wrote:
> >> Hi,
> >> I would like to ask about the status of OpenLayers language
support.
> >> There are not many strings, which could be translated, however,
some are
> >> there and IMHO we should (de)find a way, how to make this
possible. Was
> >> there some discussion to this topic?
> >> IMHO, new map attribute "lang" should be defined, as well as new
method
> >> OpenLayer.Util.getOLString("English text") (or similar).
> >> Any suggestions? Should I write something like this? Is there
already
> >> some code out there?
> > No code yet, but I agree that now is the time.
> > http://trac.openlayers.org/wiki/RFC/Internationalization
> > Is my start at an RFC, which never went far enough.
> > My belief is that we should make this a global setting, rather than
a
> > per-map configuration. This would mean you could not have multiple
> > languages on the same page at the same time, but would also mean
you
> > don't need a reference to the map object in order to get a correct
> > translation string. I don't know if the trade off is worth it. What
do
> > other people think?
> > Regards,
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20071018/6fcfefd7/attachment.html
More information about the Dev
