[OpenLayers-Dev] status of translation possibilities
Christian López Espínola
penyaskito at gmail.com
Thu Oct 18 10:40:18 EDT 2007
Hi all,
I personally prefer the style that Chris pointed in a previous discussion:
http://openlayers.org/pipermail/dev/2007-July/001017.html
About the way it should be used, an Openlayers.i18n.CURRENT_LANG
global var and an OpenLayers.i18n.setLanguage() method would be simple
and extensible.
My 2 cents.
On 10/18/07, Dan Little <danlittle at yahoo.com> wrote:
> I wouldn't think this to be too hard.
> In most internationalized applications I've seen, there is typically a
> "lang" or "strings" file that contains all of the strings for a given
> application. Then when the code needs a string it will call a global
> variable containing that error/warning/info message. This way all of the
> needed translation is isolated to a single file. Changing languages becomes
> a matter of loading an alternate language file.
> So there could be a collection of language files:
> strings.en.js
> strings.es.js
> strings.fr.js
> strnigs.de.js
> And then provide some basic facilities for switching between them. In fact,
> each of those files could be a JSON object that gets loaded to a global
> object/variable.
> I may be just spewing bad ideas... but so long as the creative juices were
> flowing I'd thought I'd share.
> -Duck
> ----- Original Message ----
> From: Jachym Cepicky <jachym.cepicky at gmail.com>
> To: Bart van den Eijnden (OSGIS) <bartvde at osgis.nl>
> Cc: "dev at openlayers" <dev at openlayers.org>
> Sent: Thursday, October 18, 2007 8:58:42 AM
> Subject: Re: [OpenLayers-Dev] status of translation possibilities
> Bart van den Eijnden (OSGIS) píše v Čt 18. 10. 2007 v 15:44 +0200:
> > Hi Chris,
> > I think it is acceptable to have a global setting. I can't imagine a
> > common use case (for myself) where one map would be in English and
> > another one in Dutch on the same page. It is important though that it is
> > possible to switch languages.
> +1
> jachym
> > Best regards,
> > Bart
> > Christopher Schmidt schreef:
> > > On Thu, Oct 18, 2007 at 03:23:50PM +0200, Jachym Cepicky wrote:
> > >> Hi,
> > >> I would like to ask about the status of OpenLayers language support.
> > >> There are not many strings, which could be translated, however, some
> are
> > >> there and IMHO we should (de)find a way, how to make this possible. Was
> > >> there some discussion to this topic?
> > >> IMHO, new map attribute "lang" should be defined, as well as new method
> > >> OpenLayer.Util.getOLString("English text") (or similar).
> > >> Any suggestions? Should I write something like this? Is there already
> > >> some code out there?
> > > No code yet, but I agree that now is the time.
> http://trac.openlayers.org/wiki/RFC/Internationalization
> > > Is my start at an RFC, which never went far enough.
> > > My belief is that we should make this a global setting, rather than a
> > > per-map configuration. This would mean you could not have multiple
> > > languages on the same page at the same time, but would also mean you
> > > don't need a reference to the map object in order to get a correct
> > > translation string. I don't know if the trade off is worth it. What do
> > > other people think?
> > > Regards,
> Jachym Cepicky
> e-mail: jachym.cepicky at gmail.com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Regards,
More information about the Dev
