[OpenLayers-Dev] vector layer does not draw at lower
resoluti ons.
Rohith Kota
rohith.kota at uai.com
Fri Oct 19 09:56:04 EDT 2007
I did try as you have suggested, but without any luck.
If you move the zoom bar to the lowest level and try to draw vector it does
not draw rather it would be on zoom level 2 bar higher.
thanks
rohith kota
327-3925
-----Original Message-----
From: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org]On
Behalf Of Arnd Wippermann
Sent: Thursday, October 18, 2007 3:09 PM
To: dev at openlayers.org
Subject: Re: [OpenLayers-Dev] vector layer does not draw at lower
resolutions.
Use this map.addLayers([layer,vlayer]); instead of
map.addLayer(layer,vlayer);
with your code only one layer will added to the map.
Arnd Wippermann
http://gis.ibbeck.de/ginfo
View this message in context:
http://www.nabble.com/vector-layer-does-not-draw-at-lower-resolutions.-tf462
9642.html#a13282676
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
Dev mailing list
Dev at openlayers.org
http://openlayers.org/mailman/listinfo/dev
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
More information about the Dev
