[OpenLayers-Dev] jslint cleanup committed
Paul Spencer pspencer at dmsolutions.ca
Fri Oct 19 15:33:40 EDT 2007
For those of you that are not on IRC, Tim and I worked this out this
afternoon and I committed:
http://trac.openlayers.org/changeset/5028
which cleans up some 29 instances of local scope variables used
without 'var', making them global in scope. This is now part of my
regularly scheduled routine :)
Cheers
Paul
On 19-Oct-07, at 1:30 PM, Tim Schaub wrote:
> Hey-
> Paul Spencer wrote:
>> for the record, I did fix the above warnings in Rico/* and did NOT
>> touch
>> firebug.  As Tim indicates, it doesn't affect the final build.  As of
>> now, the final full build is 'lint free' with my current settings,
>> which
>> makes me very happy :)  I may look at some of the other settings
>> to see
>> if there is anything else we could potentially benefit from in the
>> newer
>> version of jslint which I discovered last night ...
> Paul, I'd also be interested in the result of disallowing use of
> undefined variables.  Perhaps you already talked about this and I
> missed it.
> What would be really cool is if jslint could be tweaked to look for
> variable assignment outside of the OpenLayers namespace - something we
> occasionally stumble across and have no way of testing for.  (I know a
> case where window.i == 2 and I cannot figure out why.)  This might
> even
> be caught by the "no undefined variables" filter if it is initialized
> without the var keyword (which is likely).
> Tim
>> Cheers
>> Paul
>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>> |Chief Technology Officer                                         |
>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>> !DSPAM:4033,4718de8133771961014482!
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
