[OpenLayers-Dev] jslint cleanup committed
Tim Schaub
tschaub at openplans.org
Fri Oct 19 13:30:26 EDT 2007
Hey-
Paul Spencer wrote:
> for the record, I did fix the above warnings in Rico/* and did NOT touch
> firebug. As Tim indicates, it doesn't affect the final build. As of
> now, the final full build is 'lint free' with my current settings, which
> makes me very happy :) I may look at some of the other settings to see
> if there is anything else we could potentially benefit from in the newer
> version of jslint which I discovered last night ...
Paul, I'd also be interested in the result of disallowing use of
undefined variables. Perhaps you already talked about this and I missed it.
What would be really cool is if jslint could be tweaked to look for
variable assignment outside of the OpenLayers namespace - something we
occasionally stumble across and have no way of testing for. (I know a
case where window.i == 2 and I cannot figure out why.) This might even
be caught by the "no undefined variables" filter if it is initialized
without the var keyword (which is likely).
Tim
> Cheers
> Paul
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
> !DSPAM:4033,4718de8133771961014482!
More information about the Dev
