[OpenLayers-Dev] jslint cleanup committed
Erik Uzureau erik.uzureau at metacarta.com
Fri Oct 19 18:27:02 EDT 2007
Another wicked patch. Also tim's complementary patch
http://trac.openlayers.org/changeset/5027
...which clears the jslint complaints for the 'OpenLayers' variable.
Great job with this. Let's hope we can keep the OL codebase free
of these slips in the future. :-)
E
On 10/19/07, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> For those of you that are not on IRC, Tim and I worked this out this
> afternoon and I committed:
> http://trac.openlayers.org/changeset/5028
> which cleans up some 29 instances of local scope variables used
> without 'var', making them global in scope. This is now part of my
> regularly scheduled routine :)
> Cheers
> Paul
> On 19-Oct-07, at 1:30 PM, Tim Schaub wrote:
> > Hey-
> > Paul Spencer wrote:
> >> for the record, I did fix the above warnings in Rico/* and did NOT
> >> touch
> >> firebug.  As Tim indicates, it doesn't affect the final build.  As of
> >> now, the final full build is 'lint free' with my current settings,
> >> which
> >> makes me very happy :)  I may look at some of the other settings
> >> to see
> >> if there is anything else we could potentially benefit from in the
> >> newer
> >> version of jslint which I discovered last night ...
> > Paul, I'd also be interested in the result of disallowing use of
> > undefined variables.  Perhaps you already talked about this and I
> > missed it.
> > What would be really cool is if jslint could be tweaked to look for
> > variable assignment outside of the OpenLayers namespace - something we
> > occasionally stumble across and have no way of testing for.  (I know a
> > case where window.i == 2 and I cannot figure out why.)  This might
> > even
> > be caught by the "no undefined variables" filter if it is initialized
> > without the var keyword (which is likely).
> > Tim
> >> Cheers
> >> Paul
> >> |Paul Spencer                          pspencer at dmsolutions.ca    |
> >> |Chief Technology Officer                                         |
> >> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> >> !DSPAM:4033,4718de8133771961014482!
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
More information about the Dev mailing list
