[OpenLayers-Dev] proxyHost cgi issue (Domenico Febbo)
Jim Ing
jing at pelmorex.com
Tue Oct 23 13:28:53 EDT 2007
Domenico,
Here's one that I'm using:
http://www.jmarshall.com/tools/cgiproxy/
Just make sure your Apache httpd.conf has these settings:
LoadModule cgi_module modules/mod_cgi.so
<Directory "C:/<Insert your DocumentRoot>">
Options Indexes FollowSymLinks ExecCGI
</Directory>
AddHandler cgi-script .cgi
Also, you might need to edit the first line of nph-proxy.cgi to point to
your Perl
#!/usr/bin/perl
Jim
-----Original Message-----
Date: Tue, 23 Oct 2007 10:28:29 +0200
From: "Domenico Febbo" <domenico.febbo at gmail.com>
Subject: [OpenLayers-Dev] proxyHost cgi issue
To: dev at openlayers.org
I need to use proxy.cgi script to forward "get" request on
XMLHttpRequest object to a external host, but I have same problem with
the path to add at "url=" field.
Moreover I've tried the online script
http://dev.openlayers.org/sandbox/docs/examples/proxy.cgi
but the http://openlayers.org redirect seems to have a issue because
the OpenLayers object isn't found (try with Firebug enabled) and all
the relative path are wrong.
Somebody have other proxy script for Apache webserver?
thanks,
Domenico
More information about the Dev
