[OpenLayers-Dev] Empty geometries causing errors in IE
Cameron Shorter
cameron.shorter at gmail.com
Tue Oct 30 01:34:35 EDT 2007
Roald de Wit wrote:
> On Fri, 2007-10-26 at 09:52 -0600, Tim Schaub wrote:
>> I'm entirely in favor of this. I don't think the renderer is the right
>> place to bomb (or hey maybe even throw an exception!) on an empty geometry.
>> I think it makes sense to have our format classes throw exceptions on
>> empty geometries. They could even have an option to allow empty
>> geometry. In any case, it should be up to the application designer to
>> decide what to do with empty geometry. As library developers, I don't
>> think we should impose our beliefs about empty geometries on all others.
>> Breaking in only one browser, and only when rendering, is a bit late and
>> a bit inconsistent.
>>> See ticket #1111 for a simple 'fix'.
>> See also http://trac.openlayers.org/ticket/968
>> I'd like to see some tests for the renderers really. I haven't looked
>> closely at your patch, but it would be nice to make sure we don't slip
>> once we decide to make a change (like make browser behavior consistent).
> That fix in the patch I mentioned is probably not the best solution
> (although it worked for us).
> A few places where I can imagine we could prevent the renderer from
> trying to render the empty geometry is:
> - Renderer/Elements.js: drawGeometryNode()
> - Renderer.js: drawFeature()
> - Format/*.js: parseGeometry()
> It would be nice if we can come up with a clean solution for this.
> Roald
Chris has noted on IRC that he doesn't think VML.setNodeDimension() is
the right place to catch this error and after digging around I agree.
The problem is that a point geometry is created which has an x,y point
of (null, null). This eventually causes an exception in the VML renderer.
I propose we fix in Geometry/Point.initialize(x,y) where we should throw
an exception if x or y is null.
Reason:
1. Exceptions are already raised by Format/KML.js if it needs to create
a (null,null) point, so I believe we have a precedence for handling
errors by raising exceptions.
2. Our error was caused because Format/GML.js allows the creation of
(null,null) points, probably from an empty <Point></Point> tag.
3. I don't expect to break any legacy code by forcing Geometry to have
valid values because old code would have caused exceptions in VML.js as
we discovered.
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Software
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Dev
