[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #966: Add att
	ribution control to map by default
    Christopher Schmidt
    crschmidt at metacarta.com
    Wed Sep 12 11:10:50 EDT 2007
On Wed, Sep 12, 2007 at 10:03:07AM -0500, John Cole wrote:
> Christopher,
>   When we print maps, we are using OpenLayers, as it's still a WMS layer,
> but there is only one base layer.  When we create the OL map, we specify no
> controls at all, because these can have issues with different browsers print
> engines (sometimes the top control covers up the entire map, for whatever
> reason).  It would be nice if all the browsers behaved the similar when it
> came to printing, but to reduce the problems we strip the map down to just
> the un-tiled image and nothing else.
>   I'd like to make sure that whenever I print, no other controls exist, even
> if they are disabled.  I'm worried about an empty div section blocking the
> map during printing.  If the control has it's outer div set to display:none,
> then I doubt it would interfere, but just an empty one may cause problems.
Ah, then your'e fine with this: this only adds it to the map by
*default* -- that is, if no  controls:[] option is specified on the map.
If you specify controls: [], then the control isn't added -- I think
this was Paul's question as well, which I hope I adequately responded to
there.
This is *only* for the 'standard' default OL map -- if you want to
customize your map, we're not going to force you into a specific
direction.
With that in mind, do you forsee a problem? or was your concern just
that it would be added to the map regardless of what was specified in
the map intializer control list?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
