[OpenLayers-Dev] ArcGIS server 9.2 support for OL
Christopher Schmidt
crschmidt at metacarta.com
Mon Sep 17 07:28:33 EDT 2007
On Mon, Sep 17, 2007 at 12:11:40PM +0200, Michael ?stling wrote:
> Hi,
> I have problems using the AGS mapcache component.
> I'm getting problems fitting the map correctly.
The AGS MapCache support *does not work*. I'm sorry if this is not
clear. Where did you find it mentioned, and where could I mark more
clearly thati t does not work? Did you pull it from the sandboxes?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
