[OpenLayers-Dev] [crschmidt@metacarta.com: Re: [OpenLayers-Users]
click-event in openlayers 2.5]
Christopher Schmidt
crschmidt at metacarta.com
Mon Sep 17 12:17:27 EDT 2007
This is #982. This is a regression against 2.4 -- and I feel like it's
one we've had before, though presumably not in the same way. If anyone
wants to investigate, I think that the right place to look might be:
r3891:
#774 - drag control only calls move callback with a change in pixel
position - DragPan control simplified
Otherwise, I *think* it's got to be somewhere in:
http://trac.openlayers.org/log/trunk/openlayers/lib/OpenLayers/Handler/Drag.js?action=stop_on_copy&rev=4230&stop_rev=3198&mode=stop_on_copy&verbose=on
-- Chris
----- Forwarded message from Christopher Schmidt <crschmidt at metacarta.com> -----
From: Christopher Schmidt <crschmidt at metacarta.com>
To: nhelminger <n.helminger at visyoo.com>
Cc: users at openlayers.org
Date: Mon, 17 Sep 2007 11:47:04 -0400
Subject: Re: [OpenLayers-Users] click-event in openlayers 2.5
On Mon, Sep 17, 2007 at 07:41:28AM -0700, nhelminger wrote:
> I'm using OpenLayers 2.5.
> When dragging the map an click event is fired.
> You can try out the click.html example.
Thanks. Filed as a blocker for 2.5.
Regards,
Christopher Schmidt
MetaCarta
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
----- End forwarded message -----
Christopher Schmidt
MetaCarta
More information about the Dev
