[OpenLayers-Dev] How to change the overview control's location
Christian López Espínola penyaskito at gmail.com
Wed Sep 19 08:31:59 EDT 2007
You can do it through the CSS style.css located at the themes/default folder.
The classes are coded with the ol prefix and the name of the control.
In this case,
olControlOverviewMapContainer.
Hope this helps.
On 9/19/07, pdecker <paulad at rmi.net> wrote:
> Hello,
> I want to change the overview control's location so that when it is expanded
> it does not cover up the coordinate readout.  I can modify the OpenLayers
> code if need be.
> I may want to change the location of other controls as well.
> Thanks so much.
> -PD
> View this message in context: http://www.nabble.com/How-to-change-the-overview-control%27s-location-tf4445203.html#a12683408
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Regards,
More information about the Dev mailing list
