[OpenLayers-Dev] How to change the overview control's location
pdecker paulad at rmi.net
Wed Sep 19 14:03:46 EDT 2007
Hello,
Thank you so much, Christian.  That is a clean solution and works
splendidly!
-PD
Christian López Espínola wrote:
> You can do it through the CSS style.css located at the themes/default
> folder.
> The classes are coded with the ol prefix and the name of the control.
> In this case,
> olControlOverviewMapContainer.
> Hope this helps.
> On 9/19/07, pdecker <paulad at rmi.net> wrote:
>> Hello,
>> I want to change the overview control's location so that when it is
>> expanded
>> it does not cover up the coordinate readout.  I can modify the OpenLayers
>> code if need be.
>> I may want to change the location of other controls as well.
>> Thanks so much.
>> -PD
>> View this message in context:
>> http://www.nabble.com/How-to-change-the-overview-control%27s-location-tf4445203.html#a12683408
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Regards,
> Dev mailing list
View this message in context: http://www.nabble.com/How-to-change-the-overview-control%27s-location-tf4445203.html#a12782867
More information about the Dev mailing list
