[OpenLayers-Dev] BBOX values are out of range for EPSG:4326
pdecker paulad at rmi.net
Mon Sep 24 11:05:02 EDT 2007
Hello,
I am running example: controls.html which is found in the examples directory
of OpenLayers2.3.
One of the tile requests has a BBOX of:  -1260, 990, -900, 1350.  The
request also shows the SRS=EPSG:4326.  I thought BBOX values for
SRS=EPSG:4326 were in the range: latitude 90 to -90 and longitude 180 to
-180.
The reason I ask is because I am now getting out of range values with a map
whose coordinates are:  MinLat=32.58:59N, MaxLat=32:59:00N,
MinLon=085:00:00E, MaxLon=085:00:01E.
Can OpenLayers handle a map which is 1 second by 1 second?
Thanks in advance.
-PD
View this message in context: http://www.nabble.com/BBOX-values-are-out-of-range-for-EPSG%3A4326-tf4509740.html#a12861727
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
