[OpenLayers-Dev] VML Rendering of point data
Eric Lemoine
eric.c2c at gmail.com
Tue Sep 25 14:38:31 EDT 2007
On 9/25/07, fporcelli at taic.net <fporcelli at taic.net> wrote:
> Hello dev --
> I was wondering if anyone is aware of an issue discovered regarding rendering of KML point data using IE6. It seems the point locations are not placed at the correct coordinates when using the VML renderer with IE6. After some research I noticed that there was a documented issue in ticket #517 (http://trac.openlayers.org/ticket/517) regarding the inability to use floating point numbers in VML. It appears that this is directly related to the above issue. While this ticket is closed, is anyone aware that VML point data still is not rendering correctly? If a patch is required, I would be happy to offer up some assistance, but don't have write access to the code base.
Hi Frank,
This isn't a known issue. Could you provide more details? And possibly
post some code...
Eric
More information about the Dev
