[OpenLayers-Dev] VML Rendering of point data
fporc7ji fporcelli at taic.net
Thu Sep 27 21:38:23 EDT 2007
Hi Eric --
Here is what I am experiencing.
When reading in a KML layer using the VML renderer, the first point displays
at the correct location.
If the layer has multiple points after the first point is added a child node
is added to the root as directed in elements.drawGeometry. As soon as a
child node is appended to the root, the first point shifts and is no longer
at the correct location. Try opening the kml-layer.html example using IE6,
then use Firefox (which uses the SVG renderer). The Firefox points will be
accurate and will reflect what you would see in Google Earth, the IE6 points
do not. I've attached the OL 2.5rc3 build, with alert messages in key parts
of the renderer code. My attachment has a sample KML point layer included.
Thanks,
Frank
Eric Lemoine-3 wrote:
> On 9/25/07, fporcelli at taic.net <fporcelli at taic.net> wrote:
>> Hello dev --
>> I was wondering if anyone is aware of an issue discovered regarding
>> rendering of KML point data using IE6. It seems the point locations are
>> not placed at the correct coordinates when using the VML renderer with
>> IE6. After some research I noticed that there was a documented issue in
>> ticket #517 (http://trac.openlayers.org/ticket/517) regarding the
>> inability to use floating point numbers in VML. It appears that this is
>> directly related to the above issue. While this ticket is closed, is
>> anyone aware that VML point data still is not rendering correctly? If a
>> patch is required, I would be happy to offer up some assistance, but
>> don't have write access to the code base.
> Hi Frank,
> This isn't a known issue. Could you provide more details? And possibly
> post some code...
> Eric
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
http://www.nabble.com/file/p12933317/VML.zip VML.zip
View this message in context: http://www.nabble.com/VML-Rendering-of-point-data-tf4516302.html#a12933317
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
