[OpenLayers-Dev] Tooltips on the controls in NavToolBar
Antonio volpicelli at oato.inaf.it
Wed Sep 26 06:51:13 EDT 2007
Christian,
this seems to work only if you keep the controls on the map.
If you move the controls outside the map it doesn't work.
This are some line of my code:
<style type="text/css">
  #paneldiv { float: left;   width: 30px; }
  #paneldiv div {
    top: 10px;
<div id="paneldiv" ></div>
        var panel = new
OpenLayers.Control.Panel({'div':OpenLayers.Util.getElement('paneldiv')});
        panel.addControls([new OpenLayers.Control.ZoomBox({title: "Zoom
Box: Selecting it you can zoom on an area by clicking and draging"})]);
but how Lee write this functionality is slated for 2.6.
I will think about and hope to find a solution.
Thanks
Ciao
Antonio
Christian López Espínola wrote:
> Hi Antonio,
> See if
> http://dev.openlayers.org/sandbox/penyaskito/openlayers/examples/panel.html
> does what you want.
> If it helps, see the patch at the ticket #822
> http://trac.openlayers.org/ticket/822
> Cheers
> On 9/25/07, Antonio <volpicelli at oato.inaf.it> wrote:
>> Hi,
>> I moved the NavToolBar with some controls outside of the Map and I would
>> like to enable tooltips  on they .
>> Is there some one what I could do?
>> Thanks
>> Antonio
>>        PLEASE WARNING: E-mail is CHANGED
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070926/9fec6072/attachment.html
More information about the Dev mailing list
