[OpenLayers-Dev] Tooltips on the controls in NavToolBar
Christian López Espínola
penyaskito at gmail.com
Wed Sep 26 12:03:23 EDT 2007
Hi Antonio,
Can you attach a full example, and I can take a look at it?
On 9/26/07, Antonio <volpicelli at oato.inaf.it> wrote:
> Christian,
> this seems to work only if you keep the controls on the map.
> If you move the controls outside the map it doesn't work.
> This are some line of my code:
> <style type="text/css">
> #paneldiv { float: left; width: 30px; }
> #paneldiv div {
> top: 10px;
> <div id="paneldiv" ></div>
> var panel = new
> OpenLayers.Control.Panel({'div':OpenLayers.Util.getElement('paneldiv')});
> panel.addControls([new OpenLayers.Control.ZoomBox({title: "Zoom
> Box: Selecting it you can zoom on an area by clicking and draging"})]);
> but how Lee write this functionality is slated for 2.6.
> I will think about and hope to find a solution.
> Thanks
> Ciao
> Antonio
> Christian López Espínola wrote:
> Hi Antonio,
> See if
> http://dev.openlayers.org/sandbox/penyaskito/openlayers/examples/panel.html
> does what you want.
> If it helps, see the patch at the ticket #822
> http://trac.openlayers.org/ticket/822
> Cheers
> On 9/25/07, Antonio <volpicelli at oato.inaf.it> wrote:
> Hi,
> I moved the NavToolBar with some controls outside of the Map and I would
> like to enable tooltips on they .
> Is there some one what I could do?
> Thanks
> Antonio
> PLEASE WARNING: E-mail is CHANGED
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Regards,
More information about the Dev
