[OpenLayers-Dev] Patch for a ka-Map cached layer
Pedro Simonetti
pedrosimonetti at gmail.com
Thu Apr 10 21:24:28 EDT 2008
Hi all,
As I stated in an earlier thread [1], I've changed some part of the OL's
code to
handle ka-Map pre-cached layers, similar to the TileCache class. With a
cached
layer, the ka-Map tiles will be loaded considerably faster.
[1]
http://www.nabble.com/Fix-for-issue--327%3A-ka-Map-overlays-tc16620073.html
A long time ago [2], Jochen Grefe has posted here about a similar aproach:
[2]
http://www.nabble.com/Using-kamaps-direct-cache-access-tc11581326.html#a11581326
The solution provided by him works, but it has some small problems I'll
decribe
here. First, I thought it was more natural to make a separate KaMapCache
class,
similar to TileCache class. One problem is that when the layer's group name
(the
"g" parameter in KaMap class) has white spaces, it doesn't get the proper
url.
Another problem is related to the directory structure described above. I've
also
changed the string concatenation to the Array.splice method, as used in "
TileCache" class.
So, I wrote a new KaMapCache class, that overextends a KaMap class. This
class
overrides the "getURL" to generate the full URL of each tile, without
calling
the server.
To create a a new KaMapCache layer, you must indicate also the "i" parameter
that will be used to calculate the file extension), and another special
parameter, object names "metaTileSize", with "h" (height) and "w"
properties, as
suggested by Jochen.
Here's a simple example. Is the same example of my earlier thread [1], but
using
a KaMapCache layer.
// Create a new kaMapCache layer. You must allways inform the "i"
parameter
// for a KaMapCache layer.
var kamap_base = new OpenLayers.Layer.KaMapCache(
"Satellite",
"http://www.example.org/web/acessible/cache",
{g: "satellite", map: "world", i: 'png24', metaTileSize: {w: 5, h: 5}
// Create an kaMapCache overlay layer (using "isBaseLayer: false"). Forces
// the output to be a "gif", using the "i" parameter.
var kamap_overlay = new OpenLayers.Layer.KaMapCache(
"Streets",
{g: "streets", map: "world", i: "gif", metaTileSize: {w: 5, h: 5} },
{isBaseLayer: false}
I don't have privileges to open a new ticket so I'll put the files as an
atachment of this message. As it was stated in my earlier thread, I've
splitted
the "tile.php" in two files: "tile.php", and "config.php", so this
configuration
file can be used also with a "precache.php" file.
Like the TileCache layers, you must pre-generate all tiles before using it.
This
is done with the "precache.php" file. This file is basically the
"precache2.php"
file that comes with ka-Map distribution, with almost none changes.
Was removed a piece of code that was trying to remotely create the cache
directory. This was a useless step, once "precache.php" is a command line
tool
that will generate that folder locally.
The other change was related to the directory structure of the cache. There
was
a slighly difference between the directory generated by "precache2.php", and
the
one generated by "tile.php", the code already in use at OL.
precache2.php:
var/cache/World/50000/Group_Name/def/t-440320/l20480
tile.php:
var/cache/World/50000/Group_Name/def/t-440320l20480
I don't know why this was changed, and I would like to hear some opinions.
What's the best structure? Or both has the same performance? I mean, I
suppose
the second one would generate more folders inside the "def" folder for
smaller
scales like the street level scale. But since I'm not a hardware guru, I'm
asking here in the list. This can somehow affect the hard disk performance
or
something related?
The files used are:
* "precache.php", renamed as "precache.php.txt"
* "config.php", the same used in the my earlier's post. I'll not upload
this
again to avoid duplicities in the tracker.
* "KaMapCache.js", the new class.
I hope this patch helps.
my best regards,
Pedro Simonetti.
http://www.nabble.com/file/p16623387/KaMapCache.js KaMapCache.js
http://www.nabble.com/file/p16623387/precache.php.txt precache.php.txt
View this message in context: http://www.nabble.com/Patch-for-a-ka-Map-cached-layer-tp16623387p16623387.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
