[OpenLayers-Dev] Fix for issue #327: ka-Map overlays
Pedro Simonetti Garcia
pedrosimonetti at gmail.com
Wed Apr 16 09:54:13 EDT 2008
Hi folks,
After some discussion with Paul [1]
<http://trac.openlayers.org/changeset/1>about the directory structure
isse, I've made some changes as he suggested.
So, the patch that sould be used is this second version I'm publishing in
the issue tracker [2].
[1] <http://trac.openlayers.org/changeset/1>
http://www.nabble.com/Patch-for-a-ka-Map-cached-layer-tp16623387p16623662.html
[2] http://trac.openlayers.org/ticket/327
The patch for the KaMapCache layer with the proper modifications comes next.
My best regards,
Pedro Simonetti.
2008/4/10, Pedro Simonetti <pedrosimonetti at gmail.com>:
> Hi all,
> I'm doing an upgrade in the Veracidade project that was initially made
> over
> ka-Map.
> http://www.veracidade.com.br/
> Were upgrading the whole project. We're upgrading our imagery database and
> including new featues, so I felt a good step to migrate to OpenLayers,
> giving the benefits OL offers to customization and user interaction.
> As every project, we have a limited schedule, but I hope this jorney will
> bring some goodies to the OL community, specially for those using
> OL+ka-Map.
> I've made some changes in the OL's ka-Map interface, and I would like to
> share this with you all. I'll break those changes in different threads to
> make it easier to future research.
> So here we go. There is a problem in the "tile.php" file (named
> "examples/kamap.txt") related to ka-Map overlays.
> The solution is actually very simple. The code was missing to uppercase
> the
> output format, so if you set your map in .js with "i" equals to "gif", the
> code won't cacth this, and will use de default value from "tile.php"
> configuration section.
> I've break this file in two files "tile.php" and "config.php" to allow a
> single configuration file be shared with both "tile.php" and
> "precache.php"
> (I'll discuss prepache changes in another thread).
> I'll posting a patch on the tracker for this issue.
> Here goes a suggestion. Since there will be 3 different php files related
> to
> ka-Map, I think will be good, to create another directory for those files,
> maybe in "examples/kaMap", for example. I think also that is good to put
> those files named "tile.php.txt", "config.php.txt", and
> "precache.php.txt",
> to a better readibility.
> This changes required a little change in KaMap.js, because the constant
> "OpenLayers.Layer.KaMap.DEFAULT_PARAMS" souldn't be used, as the default
> output format is taken from "config.php" file.
> So, I'll post in the tracker a separated patch for this.
> Here a simple example of creating two ka-Map layers:
> // The output format used will be that informed at "config.php",
> // since the parameter "i" was not used.
> var kamap_base = new OpenLayers.Layer.KaMap(
> "Satellite",
> "http://www.openlayers.org/world/tile.php",
> {g: "satellite", map: "world"}
> // Create an ka-Map overlay layer (using "isBaseLayer: false"). Forces
> // the output to be a "gif", using the "i" parameter.
> var kamap_overlay = new OpenLayers.Layer.KaMap(
> "Streets",
> {g: "streets", map: "world", i: "gif"},
> {isBaseLayer: false}
> regards,
> Pedro Simonetti.
> http://www.nabble.com/Fix-for-issue--327%3A-ka-Map-overlays-tp16620073p16620073.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080416/9e45e6a7/attachment.html
More information about the Dev
