[OpenLayers-Dev] [OpenLayers-Users] Delete Feature
Benoit PESTY tchule at hotmail.com
Mon Apr 14 08:15:52 EDT 2008
Hello,
I've mixed the mailing lists, I'm lost in my own mails, sorry for the disturbance.
Thanks to your example Arnd, I've come up with an ugly solution to my problem.
I've changed my delete method like this:
 * Delete a feature
function deleteFeature(feature) {
    modifyTool.unselectFeature(feature);   // modifyTool is my ModifyFeature Control
    getEditableLayer().removeFeatures(feature);
But it's not very satisfying. It seems that the ModifyFeature control register the "featureselected" event on the layer and generate some temporary vertices event is the control should be disabled (in the toolbar it is toogled off). The cleaner solution would be to generate theses vertices only the the control is on.
Tchule.
i have enhanced the ModifyFeature Control, so that I can delete a feature
with the key 'k' like kill.
OpenLayers.Control.ModifyFeature.prototype.deleteCodes = [46, 100, 107];
//Backspace, d, k
OpenLayers.Control.ModifyFeature.prototype.handleKeypress = function(code) {
        else if(this.feature && OpenLayers.Util.indexOf(this.deleteCodes,
code) != -1 && code == 107)
            var obj = this.feature;
            var lyr = obj.layer;
            this.unselectFeature(obj);
            lyr.removeFeatures(obj);
            msg ="201:" + code;
        //alert(msg);
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
> Hello,
> I've discovered that my problem is link with the presence of the
> "ModifyFeature" control that changes the behaviour of the Select control.
> I'm a bit lost with these controls and the removeFeatures/ eraseFeatures /
> destroyFeatures methods of the Vector class.
> Does someone have a clean example of how to create an Editing Toolbar with
> - The create point / line / polygone buttons
> - A Delete Feature button
> - A Modify Feature button
> Thanks,
    To: users at openlayers.org
    Subject: Delete Feature
    Date: Mon, 7 Apr 2008 15:36:30 +0000
    Hello,
    I have a stupid error when trying to delete a vector feature. I've updated OpenLayers from 2.5 to 2.6 (latest from trunk) and when trying to delete a feature I have the corners of the polygon that stay on the map.
    I've added a control like this :
    // Delete feature
    var deleteTool = new OpenLayers.Control.SelectFeature(layer_vector,
               onSelect:deleteFeature,
    And the called method is like this :
    The problem seems to be that when getting the vector layer (thru the getLayersByName() method) the feature is set to "modification mode".
    I've tried to look around for the "renderIntent" property of the selectfeature control but I don't know the clean way to use it.
    Thanks,
    Benoit Pesty
_________________________________________________________________
More immediate than e-mail? Get instant access with Windows Live Messenger.
http://www.windowslive.com/messenger/overview.html?ocid=TXT_TAGLM_WL_Refresh_instantaccess_042008
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080414/e5523df8/attachment.html
More information about the Dev mailing list
