[OpenLayers-Dev] vector behavior
Christopher Schmidt crschmidt at metacarta.com
Tue Apr 15 01:51:35 EDT 2008
On Mon, Apr 14, 2008 at 10:02:13PM -0400, Christopher Schmidt wrote:
> On Mon, Apr 14, 2008 at 05:46:47PM -0600, Tim Schaub wrote:
> > Hey-
> > Some may have already seen the proposal for new vector layer behavior.
> > http://trac.openlayers.org/wiki/Proposal/VectorBehavior
> > This week, I'll be working on implementing a bit of this new design.
> > I'm focussed on an AtomPub protocol, an Atom format, and a somewhat
> > smartish BBOX strategy.
> Thanks for the email letting us know what's up.
> Out of curiosity: some Protocols seem likely to be 'trapped' within a
> single Format. I'm assuming that you don't see any problem with that, so
> long as it is sufficiently documented. I'm asking only because the
> majority of protocols seem to clearly be in a position where they'll be
> able to cope with many formats -- WFS read support, AtomPub support,
> etc. -- while a minority -- ESRI-REST, WFS-T/write, etc. -- are tied to
> a specific Format. Does this make sense? Is a format-specific protocol
> still a protocol? (I think yes.)
Alright, based on my assumption, I've gone ahead and implemented Google
Gears and HTML5 Local Storage support.
http://crschmidt.net/mapping/localdb/ . Patch is at
http://crschmidt.net/~crschmidt/localdb.patch ; it's in SVK. When you
guys are done on your push, let me know, and we can talk about the best
way to integrate.
This demo uses the local database in your browser to store features.
read(), create(), update(), delete() are committed: my assumption at
this point is that commit() will eventually be implemented on the base
Protocol() class, so I didn't bother to implement that method.
I would not recommend anyone using this code for long term anything at
the moment, since at the very least there is an obvious use case for a
four-tuple based 'bbox' query, but it was a way to get a quick proof of
concept up in a night.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
