[OpenLayers-Dev] Patch for the Brazilian Portuguese Dictonary
Pedro Simonetti Garcia
pedrosimonetti at gmail.com
Wed Apr 16 10:43:00 EDT 2008
Hi Devs,
Here's a simple one: the patch for the brazilian portuguese.
During the translation process I've noted some things I would
like to point out.
In 'minZoomLevelError' definition, the "That this" is wrong isn't?
It should be "this" or "that" only. Next in 'minZoomLevelError',
theres a mention on "min/max resolution setting". This shouldn't
be minScale/maxScale?
'minZoomLevelError':
"with the FixedZoomLevels-descendent layers. That this " +
"use min/max resolution setting as described here: " +
Another small thing. On 'getLayerWarning' the "either" should
be removed.
'getLayerWarning':
"Most likely, this is because the ${layerLib} library " +
"script was either not correctly included.<br><br>" +
One question. Is a desired feature to make a auto-detect
language on OL startup? I think this could be a good feature.
What's the best method to activate a different language
with the actual API?
I'm opening a new ticket to this patch:
http://trac.openlayers.org/ticket/1519
regards,
Pedro Simonetti.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080416/8deecd49/attachment.html
More information about the Dev
