[OpenLayers-Dev] Markers reprojection
Christopher Schmidt crschmidt at metacarta.com
Mon Apr 21 13:56:49 EDT 2008
On Mon, Apr 21, 2008 at 10:52:03AM -0400, Julien-Samuel Lacroix wrote:
> Hi,
> I need to add Markers and Vectors on a SphericalMercator map. My
> coordinates are in degree instead of meters. The projection member is
> not supported in the Markers and Vector Layer class. Is there a reason
> for that?
In general, there is no good place that we can know that we should be
reprojecting on these layers.
> I know I could reprojection all the LatLon object I create individually,
> but it would be more easier to have it directly in the Layer. I could
> open a ticket and submit a patch if you feel it worth going in the trunk.
Where do you think the reprojection code would live in this case? I
don't like the idea of touching someone else's geometry. In the case of
a Layer.GML or some such, the format is creating the geometry, so it
never belonged to someone else to begin with, but with Layer.Vector and
Layer.Marker, that's less true.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
