[OpenLayers-Dev] 2.7 ticket list
Pedro Simonetti Garcia pedrosimonetti at gmail.com
Mon Apr 28 21:10:14 EDT 2008
Christopher,
This is not a reason to fork a project!
Okay, you've convinced myself :)
Since OL is a front-end application, isn't appropriate to
maintaing server code in it.
I'll create an account in OL's track to get involved with the
KaMapCache layer.
Meanwhile, I'll communicate with the ka-Map list, and start
writing a basic how-to ka-Map+OL. If there's anyone else
interested in help, it will me much appreciated.
regards,
Pedro Simonetti.
2008/4/28 Christopher Schmidt <crschmidt at metacarta.com>:
> On Sun, Apr 27, 2008 at 10:42:16PM -0500, Stephen Woodbridge wrote:
> > Chris,
> > I sympathize with your sentiment that tile.php and precache.php not
> > being part of OpenLayers, but I think it is very useful to have them
> > with the examples, for a couple of reasons.
> > 1) it keeps a version that we know works because it has been tested,
> > with the code
> > 2) it makes it easy for people to find these as they may not have come
> > from the ka-map project but might still want to use the,
> So, let's look at other code that this might apply to:
>  * TileCache
>  * MapServer
>  * GeoServer
>  * Worldwind tile server
>  * GDAL2tiles
> All of these have changing versions, some of which will work interact
> differently with the outside world between different versions, all of
> which might not be the first place that people will look.
> However, I don't think it's a sane expectation that OpenLayers is going
> to host the code for any of these.
> In fact, the primary reason, in my opinion, that this is special for
> ka-Map is two-fold:
>  * The ka-Map project has experienced a long-term dearth of development,
>   in part due to the success of OpenLayers as a web-mapping frontend.
>   This means that for the past year or more, there has been limited
>   support for ka-Map from the people who know it best, and that affects
>   many things, like documentation, releases, etc. This happens in Open
>   Source, and I'll admit that OpenLayers is at least partially
>   responsible, as developer attention has been focused elsewhere.
>  * ka-Map was never designed for external use as a separable client and
>   server side components. As such, the documentation for the
>   server-side components on their own was never particularly seperable,
>   and the end result was that the server side was only described as
>   part of the whole process.
> These two things combine to make ka-Map a less than palatable solution
> for users concentrating on OpenLayers, because the server-side
> components of ka-Map are not easy to set up using the documentation
> available from the ka-Map project at this time. However...
> Make no mistake: maintaining seperate copies of the ka-Map source code
> in OpenLayers is a fork. We should not fork any project for convenience:
> all the difficulties that exist in using ka-Map in OpenLayers are easily
> solvable. Most are solvable without code: documentation is the only
> thing that most of these problems need, and documentation can be easily
> written in the OpenLayers wiki, the ka-Map wiki, etc.
> Helping the ka-Map project out by working to document a seperable
> server-side component, one designed for use in other applications like
> OpenLayers, would be useful to many people, and probably not just
> OpenLayers. That's the appropriate place to solve the problem of ka-Map
> source code not being effectively documented or clearly available:
> forking the project is a mistake, and my first step towards doing so
> with the tile.php in examples/ was a faux paus that I should have
> corrected long ago. If there are people who are interested in solving
> problems within the ka-Map code, we should not continue to solve them in
> OpenLayers, where only OpenLayers users benefit.
> Get involved. Help bring life to the ka-Map server side project, kick
> out a release, get SVN access, and help out the people who spent so much
> time writing the code in the first place.
> Regards,
> Christopher Schmidt
> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080428/855fe2d7/attachment.html
More information about the Dev mailing list
