[OpenLayers-Dev] svn 1.5
Attila Csipa
plists at prometheus.org.yu
Tue Aug 12 18:15:46 EDT 2008
On Tuesday 12 August 2008 22:30:34 Christopher Schmidt wrote:
> > Catching up with mails after a pause... Why not backport the lenny
> > version yourself ? With pbuilder (which _is_ present in etch) it's really
> > easy and it won't mess up your base system.
> Because I don't want to :) I'm not a sysadmin by trade, and I prefer to
> let someone else (Debian) do most of my sysadmin work for me.
Perfectly valid reason :) Just wanted to point out that backporting/installing
stuff from other/newer (official) repositories is much simpler, cleaner and
safer than it used to be (as in less than 10 lines total and not borking your
existing packages in the process). If you need gdal 1.5 or pgrouting on an
etch or hardy machine, pbuilder is your best friend anyway :)
More information about the Dev
