[OpenLayers-Dev] Cannot set ID of a control
Erik Uzureau euzuro at gmail.com
Thu Aug 21 18:37:14 EDT 2008
Hi Stephen. I have made a ticket and patch for this issue.
It is here:
http://trac.openlayers.org/ticket/1687
If approved, it will be in the OpenLayers 2.7 release.
Thanks for the heads up on this.
Erik
2008/7/2 Stephen Irons <stephen.irons at clear.net.nz>:
> ---------- Forwarded message ----------
> From: Stephen Irons <stephen.irons at gmail.com>
> Date: 2008/7/3
> Subject: Cannot set ID of a control
> To: dev at openlayers.org
> I want to have two mouse position controls on a map (for two different
> coordinate systems), but by default they appear on top of each other. I
> thought I would specify an ID for each control then, in the stylesheet, I
> could position them independantly.
> This did not work: the mouse position control ignored the 'id' attribute.
> In OpenLayers/Control.js, around lines 170--180, the id is set as the last
> thing in init() function -- after applying the options passed in by the
> caller.
> I think that the line of code
> this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
> should be moved to before
> OpenLayers.Util.extend(this, options);
> This applies to the 2.6 stable release as well as svn7462
> Stephen Irons
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
