[OpenLayers-Dev] problem with updateSize
Erik Uzureau
euzuro at gmail.com
Thu Aug 21 19:25:29 EDT 2008
http://trac.openlayers.org/ticket/1692
On Wed, Dec 12, 2007 at 7:35 AM, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> On Wed, Dec 12, 2007 at 01:11:35PM +0100, Bart van den Eijnden (OSGIS) wrote:
>> Hi list,
>> we've encountered a potential problem with updateSize in OL 2.5.
>> The updateSize function causes all invisible baselayers to request an image
>> from their WMS service. At least for WMS untiled, I haven't checked other
>> types.
> This doesn't surprise me: Can you file this as a bug so it doesn't get
> lost?
> -- Chris
>> I've created an example which can be used to reproduce, the easiest is to
>> watch the Net console of Firebug.
>> <html xmlns="http://www.w3.org/1999/xhtml">
>> <head>
>> <style type="text/css">
>> #map {
>> width: 400px;
>> height: 500px;
>> border: 1px solid black;
>> </style>
>> <script src="../lib/OpenLayers.js"></script>
>> <script type="text/javascript">
>> var map;
>> function resize() {
>> document.getElementById('map').style.width = '600px';
>> document.getElementById('map').style.height = '800px';
>> map.updateSize();
>> function init(){
>> OpenLayers.DOTS_PER_INCH = 90.714;
>> map = new OpenLayers.Map( 'map', { 'projection': 'EPSG:28992',
>> 'units':'m', 'maxExtent': new
>> OpenLayers.Bounds(0,300000,300000,600000),'scales': [2000000, 1500000,
>> 1000000, 750000, 500000, 375000, 250000, 100000, 50000, 25000, 10000, 5000,
>> 2500, 1000]});
>> var layer = new OpenLayers.Layer.WMS( "Provincies",
>> "http://www.rijkswaterstaat.nl/services/geoservices/overzichtskaartnl?",
>> {layers: 'NL-prov,bebouwing', 'format':'image/gif', 'transparent':'TRUE'},
>> {'ratio':1, singleTile: true, isBaseLayer: true} );
>> map.addLayer(layer);
>> var layer = new OpenLayers.Layer.WMS( "Dijkringgebieden",
>> "http://www.rijkswaterstaat.nl/services/geoservices/basispakket/grenzen?",
>> {layers: 'AAA205', 'format':'image/gif', 'transparent':'TRUE'}, {'ratio':1,
>> singleTile: true, isBaseLayer: true, visibility: false} );
>> if (!map.getCenter()) map.zoomToMaxExtent();
>> map.addControl( new OpenLayers.Control.LayerSwitcher() );
>> </script>
>> </head>
>> <a href="javascript:resize()">Resize</a>
>> <body onload="init()">
>> <div id="map"></div>
>> </body>
>> </html>
>> TIA.
>> Best regards,
>> Bart
>> OSGIS, Open Source GIS
>> http://www.osgis.nl
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Christopher Schmidt
> MetaCarta
> Dev mailing list
More information about the Dev
