[OpenLayers-Dev] problem with updateSize
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Aug 22 12:44:33 EDT 2008
Hi Erik,
the bug was already filed and fixed:
http://trac.openlayers.org/ticket/1207
I'll close 1692 as a duplicate of 1207.
Best regards,
Bart
Erik Uzureau wrote:
> http://trac.openlayers.org/ticket/1692
> On Wed, Dec 12, 2007 at 7:35 AM, Christopher Schmidt
> <crschmidt at metacarta.com> wrote:
>> On Wed, Dec 12, 2007 at 01:11:35PM +0100, Bart van den Eijnden (OSGIS) wrote:
>>> Hi list,
>>> we've encountered a potential problem with updateSize in OL 2.5.
>>> The updateSize function causes all invisible baselayers to request an image
>>> from their WMS service. At least for WMS untiled, I haven't checked other
>>> types.
>> This doesn't surprise me: Can you file this as a bug so it doesn't get
>> lost?
>> -- Chris
>>> I've created an example which can be used to reproduce, the easiest is to
>>> watch the Net console of Firebug.
>>> <html xmlns="http://www.w3.org/1999/xhtml">
>>> <head>
>>> <style type="text/css">
>>> #map {
>>> width: 400px;
>>> height: 500px;
>>> border: 1px solid black;
>>> </style>
>>> <script src="../lib/OpenLayers.js"></script>
>>> <script type="text/javascript">
>>> var map;
>>> function resize() {
>>> document.getElementById('map').style.width = '600px';
>>> document.getElementById('map').style.height = '800px';
>>> map.updateSize();
>>> function init(){
>>> OpenLayers.DOTS_PER_INCH = 90.714;
>>> map = new OpenLayers.Map( 'map', { 'projection': 'EPSG:28992',
>>> 'units':'m', 'maxExtent': new
>>> OpenLayers.Bounds(0,300000,300000,600000),'scales': [2000000, 1500000,
>>> 1000000, 750000, 500000, 375000, 250000, 100000, 50000, 25000, 10000, 5000,
>>> 2500, 1000]});
>>> var layer = new OpenLayers.Layer.WMS( "Provincies",
>>> "http://www.rijkswaterstaat.nl/services/geoservices/overzichtskaartnl?",
>>> {layers: 'NL-prov,bebouwing', 'format':'image/gif', 'transparent':'TRUE'},
>>> {'ratio':1, singleTile: true, isBaseLayer: true} );
>>> map.addLayer(layer);
>>> var layer = new OpenLayers.Layer.WMS( "Dijkringgebieden",
>>> "http://www.rijkswaterstaat.nl/services/geoservices/basispakket/grenzen?",
>>> {layers: 'AAA205', 'format':'image/gif', 'transparent':'TRUE'}, {'ratio':1,
>>> singleTile: true, isBaseLayer: true, visibility: false} );
>>> if (!map.getCenter()) map.zoomToMaxExtent();
>>> map.addControl( new OpenLayers.Control.LayerSwitcher() );
>>> </script>
>>> </head>
>>> <a href="javascript:resize()">Resize</a>
>>> <body onload="init()">
>>> <div id="map"></div>
>>> </body>
>>> </html>
>>> TIA.
>>> Best regards,
>>> Bart
>>> OSGIS, Open Source GIS
>>> http://www.osgis.nl
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Christopher Schmidt
>> MetaCarta
>> Dev mailing list
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev
