[OpenLayers-Dev] Text Layer and loadstart
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Fri Aug 22 12:42:16 EDT 2008
Hi Erik,
I haven't been using the Text layer that much lately to be honest, but
this changeset looks to have fixed that issue.
Though if I read the code correctly, it seems that loadstart is
triggered twice? First in moveTo and then in loadText? This was fixed
for GeoRSS [1], but maybe not for Text.
[1] http://trac.openlayers.org/ticket/1580
Best regards,
Bart
Erik Uzureau wrote:
> Bart, Chris,
> I just looked in the code in trunk and this no longer seems to be the case....
> Looks like this changeset got it:
> http://trac.openlayers.org/changeset/5828#file2
> Can you confirm?
> Erik
> On Wed, Dec 19, 2007 at 9:54 AM, Christopher Schmidt
> <crschmidt at metacarta.com> wrote:
>> On Wed, Dec 19, 2007 at 09:51:25AM +0100, Bart van den Eijnden (OSGIS) wrote:
>>> Hi list,
>>> with the current code it seems impossible to listen to a loadstart event on
>>> the Text Layer, since it already fires this event in the constructor.
>>> Or am I missing something?
>> Nope. That's a bug. The load should not actually be started in
>> initialize: instead, it should be started in moveTo, if it's not yet
>> loaded. Layer.GML does this, Layer.GeoRSS and Layer.Text do not. A patch
>> for this would be great. Please open a ticket -- if you plan to work on
>> it, or work with someone else on it, pleaes put it in 2.6 and I'll
>> review when it's completed.
>> Regards,
>> Christopher Schmidt
>> MetaCarta
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev mailing list
