[OpenLayers-Dev] Text Layer and loadstart
Erik Uzureau euzuro at gmail.com
Fri Aug 22 13:05:14 EDT 2008
good looking out, bart. I've opened a ticket
http://trac.openlayers.org/ticket/1696
if you feel like making the patch, i'll approve it. otherwise, i can
make it when i get some freetime
erik
On Fri, Aug 22, 2008 at 11:42 AM, Bart van den Eijnden (OSGIS)
<bartvde at osgis.nl> wrote:
> Hi Erik,
> I haven't been using the Text layer that much lately to be honest, but this
> changeset looks to have fixed that issue.
> Though if I read the code correctly, it seems that loadstart is triggered
> twice? First in moveTo and then in loadText? This was fixed for GeoRSS [1],
> but maybe not for Text.
> [1] http://trac.openlayers.org/ticket/1580
> Best regards,
> Bart
> Erik Uzureau wrote:
>> Bart, Chris,
>> I just looked in the code in trunk and this no longer seems to be the
>> case....
>> Looks like this changeset got it:
>> http://trac.openlayers.org/changeset/5828#file2
>> Can you confirm?
>> Erik
>> On Wed, Dec 19, 2007 at 9:54 AM, Christopher Schmidt
>> <crschmidt at metacarta.com> wrote:
>>> On Wed, Dec 19, 2007 at 09:51:25AM +0100, Bart van den Eijnden (OSGIS)
>>> wrote:
>>>> Hi list,
>>>> with the current code it seems impossible to listen to a loadstart event
>>>> on
>>>> the Text Layer, since it already fires this event in the constructor.
>>>> Or am I missing something?
>>> Nope. That's a bug. The load should not actually be started in
>>> initialize: instead, it should be started in moveTo, if it's not yet
>>> loaded. Layer.GML does this, Layer.GeoRSS and Layer.Text do not. A patch
>>> for this would be great. Please open a ticket -- if you plan to work on
>>> it, or work with someone else on it, pleaes put it in 2.6 and I'll
>>> review when it's completed.
>>> Regards,
>>> Christopher Schmidt
>>> MetaCarta
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> OSGIS, Open Source GIS
> bartvde at osgis.nl
> http://www.osgis.nl
More information about the Dev mailing list
