[OpenLayers-Dev] Problem with cluster strategy
Tim Schaub tschaub at opengeo.org
Mon Dec 1 13:12:18 EST 2008
Hey-
Eric Lemoine wrote:
> Hi Jérome
> What about registering a beforefeaturesadded listener and having this
> listener calculate the max value? That should do the trick...
> Eric
> 2008/11/26, Jerome Freyre <jerome.freyre at hispeed.ch>:
>> Hi Ivan,
>> Ok for the sample but the main goal of my post was a suggestion to display
>> correctly the cluster on a map.
>> I think that the sample is not a correct representation of the reality.
>> The addition of a function that get the max value present permit to display
>> correctly the cluster and have a radius that correspond to the reality.
>> In the sample formula, if you have a cluster that aggregate 100 features and
>> an other that aggregate 20 feature they will be displayed with the same
>> radius.
>> With my function the radius will be correctly adapted and we have a correct
The job of the cluster strategy is to cluster features.  It does not
deal with the display of those clusters.  That is up to you.
If you want to render a feature with a point radius that is derived from
some feature attribute, you would create a style with a symbolizer that
looked something like this:
var symbolizer = {
     pointRadius: "${count}"
Assuming your features have an attribute called "count" and you want
that to be the pixel radius of your rendered features.
If you want to create a symbolizer with properties that are not based on
literal feature attributes, you can use an arbitrary function to derive
properties based on any property of a feature.
Again, none of this has to do with the cluster strategy.  For an example
of features styled based on a literal feature attribute and based on an
arbitrary function, see
http://openlayers.org/dev/examples/styles-context.html
Not sure if any of this will help you achieve the "correct
representation of the reality," but you do have quite a bit of control
over how your features are styled.
Tim
>> Sincerly,
>> Jérome
>> Ivan Grcic-2 wrote:
>>> HI Jerome,
>>> Function Math.min(feature.attributes.count, 7) + 3 was just a sample
>>> in the demo. You can use whatever function you need, just take care to
>>> make it as simple as possible, because it runs trought it for every
>>> feature in cluster.
>>> Cheers, Ivan
>>> Ivan Grcic
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> View this message in context:
>> http://www.nabble.com/Problem-with-cluster-strategy-tp20701364p20702430.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
> Dev mailing list
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
