[OpenLayers-Dev] Ticket #1666
VR26A
vinci.w.cat at gmail.com
Mon Dec 1 13:23:56 EST 2008
@Stefano Bonnin
> What's the correct mailing list for getting information about ticket
> #1666 progress?
You can refer to the thread:
http://n2.nabble.com/-1666---One-Single,-Mother-Of-All-Vector-Layers-td1340452.html
I am the one who is using this patch. IE actually has more problem than I
posted previously:
1. the evt.target is not work in IE, IE support evt.srcElement only
solution: you can make use of prototype.js event model to simplify your code
(Wrapped by OpenLayer.Event)
beware the IE support DOM Level 2 event poorly.
2. if you add the feature once, IE work ok; but if you get the feature from
a rendered layer, the mother layer cannot hold the correct position when you
move the map or zoom.
The solution I found is tricky: detach the sub-tree of the lowest group of
each rendered layer (root is group) to the mother layer*. Features needed be
kept in their source layer, and every feature VML element need to have a
additional groupName other than the featureId to tell the event handler
where to go to find the feature for event processing. (groupName->source
Layer (slayer)->feature = slayer.getFeaturebyId(featureId))
* the tree detaching is for VML engine only, SVG will have problems about
this. (Canvas is unkown, but it should similar to SVG)
3. After fixing the position, the z-order come to be a problem: the layer
disappear after certain zoom-ins.
***No solution***
Hope it help
Matthias Pohl wrote:
> @Stefano Bonnin
>> #1666 progress?
> this list should be ok.
> OL-Wiki: http://trac.openlayers.org/ticket/1666
> We know about the IE issues and tried to fix some JS bugs in IE but with
> only limited success. The patch works fine with firefox. When we have
> some spare time, we will give IE debugging another try.
> Regards, Matthias
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://n2.nabble.com/Ticket--1666-tp1599114p1599934.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
