[OpenLayers-Dev] Fwd: IE cluster/protocol error - 'status' is null
or not an object
Ivan Grcic
ivan.grcic at geofoto.hr
Thu Dec 4 05:01:44 EST 2008
aaargh another IE(7) issue :( It occurs on IE when youre using
cluster strategy.
Its easily reproducible:
1) open http://openlayers.org/dev/examples/strategy-cluster.html ->
everything shows up ok
2) hit refresh ur enter the page again (hit enter on url address) -
cluster dont appear and attached error shows up ;(
3) you can reload page again and again and again.....move/zoom map
hoping the features will load...... but nothing happens until you dont
clear ur IE cache and load page again!
I dont know if its a problem about protocol or cluster....
Please do you know how can this be quickly solved?
Thank you!
Regards,
Ivan Grcic
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081204/3628ce36/ie_cluster_protocol.jpg
More information about the Dev
