[OpenLayers-Dev] Constructor and functions of the same class
Vidal, Antoni antoni.vidal at icc.cat
Thu Dec 4 09:24:13 EST 2008
Forget it !
I got the answer. The context of "this" is Measure object.
The new question is: How can I access a function in EditingTolbar.js with a value of longitude var in new line
layer.events.register("beforefeaturemodified", controls[1], function(e){var longitude = this.getBestLength(e.feature.geometry)});
I would like to pass "longitude" to handleMeasurementsPartial: function(event) {...}
In other words, how can I call the father (superclass) of Measure ? In this case is EditingToolbar.
Thank's again.
-----Mensaje original-----
De: Vidal, Antoni
Enviado el: jueves, 04 de diciembre de 2008 13:48
Para: 'dev at openlayers.org'
Asunto: Constructor and functions of the same class
Hello,
I added the fllowing lines into the initialize function of the EditingToolbar class:
Controls[1] = new OpenLayers.Control.Measure(OpenLayers.Handler.Path, OpenLayers.Util.extend({displayClass: 'olControlDrawFeaturePath', title:_("Longitude")}, measureOptions));
layer.events.register("beforefeaturemodified", controls[1], function(e){this.mesurar(e.feature.geometry)});
and bellow the function:
          mesurar: function(g) {
              alert("works!");
When I execute it, it generates the error: "this.mesurar is not a function"
Why the constructor don't understand mesurar as a function of his class?
Thank's a lot
Antoni Vidal
Institut Cartogràfic de Catalunya    Tel: +34-93 567 1500 Ext. 3228
Parc de Montjuïc                             Fax: +34-93 567 1567
08038 Barcelona                            http://www.icc.cat <http://www.icc.cat/>
Spain
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081204/45df8f94/attachment.html
More information about the Dev mailing list
