[OpenLayers-Dev] Map services supported by OpenLayers
Abdul Rauf
raufbutt at gmail.com
Sun Dec 7 14:09:12 EST 2008
Thanks for your reply. I've been through these layers but not all of them
are map services and some support vector graphic data.Would you please help
me to figure out the exact map services out of this list of layers and any
other if you know
Regards
On Sun, Dec 7, 2008 at 6:06 PM, Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
> wrote:
> If you look at the documentation:
> http://dev.openlayers.org/releases/OpenLayers-2.7/doc/apidocs/files/OpenLayers/Layer-js.html
> You can see the list of avalible layer classes.
> This corresponds roughly to the avalible map services that are supported.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Abdul Rauf skrev:
> Hi,
> I want to know the list of map services that are supported by OpenLayers
> (both the standard and non-standard)
> Any help in this regard would be very welcome
> Regards
> Dev mailing listDev at openlayers.orghttp://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081207/6cbaf721/attachment.html
More information about the Dev
