[OpenLayers-Dev] Format.KML and maxDepth: NetworkLinks not working?
bartvde at osgis.nl
bartvde at osgis.nl
Tue Dec 9 05:14:06 EST 2008
Hi list,
reading the Format.KML code it seems NetWorkLinks are not working right
now. Can anybody confirm this before I open up a ticket?
Since parseData puts in this.maxDepth as options.depth:
// Set default options
var options = {
depth: this.maxDepth,
styleBaseUrl: this.styleBaseUrl
return this.parseData(data, options);
the check in parseLinks will always return false:
parseLinks: function(nodes, options) {
// Fetch external links <NetworkLink> and <Link>
// Don't do anything if we have reached our maximum depth for
recursion
if (options.depth >= this.maxDepth) {
return false;
so no NetWorkLinks will be fetched regardless of the maxDepth value passed
in to the Format.KML constructor.
I think the code should read:
var options = {
depth: 0,
but I might be mistaken ....
TIA.
Best regards,
Bart
More information about the Dev
