[OpenLayers-Dev] [OpenLayers-Users] WMS GetCapabilities parser
bartvde at osgis.nl
bartvde at osgis.nl
Tue Dec 9 09:09:20 EST 2008
Hi Andreas,
I'll look into solving issue 1, good catch. I agree on 2) and 3).
With 4) I don't really agree, since 0.1 is a very arbitrary used version
by Mapserver. Since it is the version of the application schema, it should
not be used at all IMHO. I think the person calling the parser is
responsible for putting the version in the constructor, since he also knew
the version when doing the DescribeFeatureType request (version is a URL
parameter there). I've used this approach in the test cases. What do you
think?
Best regards,
Bart
> Hey Bart-
> Eijnden, Bart van den (DID) wrote:
>> 1) a response can have multiple typeNames, so now I've changed the
>> output for attributes to have a multi-dimensional array i.e.
>> attributes[layer][attribute].name. Is this okay with you guys since this
>> changes your interface?
> The problem I see with your change that the new structure does not know
> the typeName. So you would either have to make attributes a hash keyed
> by typeName, or stick with attributes as it was and add a typeName
> property to each attribute.
> I think the latter is easier to handle in most use cases, but I have no
> strong preference.
>> 2) for type should we remove the namespace or not? Now we can have
>> xsd:string, xs:string and string e.g.
> Since what we are parsing here is an XML Schema, we could in principle
> also have complex types that are defined in the schema. So I would say
> the type should be without namespace prefix, but there should be an
> additional property called typeNS or something, containing the namespace
> URI of the type.
>> 3) should we not also parse minOcccurs and nillable attributes? A WFS
>> client needs to know this in order to know if the element can be
>> ommitted or not. But maybe this quite specific and only used by Ionic
>> and we should leave this for a future version?
> I think this is useful information and can be added without much effort.
>> 4) I've removed using the version of the root node, since this is not
>> the WFS version but the application schema's version, see:
>> http://lists.opengeospatial.org/pipermail/wfs-dev/2008-December/000521.html
> Good catch. GeoServer does not return a version at all, so the best
> thing to do would be to set defaultVersion to "0.1" and rename the
> versioned parser v1_0.js to v0_1.js.
>> Btw, feel free to edit the bartvde/owsformats sandbox. I hope we can
>> quickly put this into a patch for OL trunk
> I'd say let's also hear Tim's opinion (and others can chime in as well
> if they feel like), but from what I see making these final changes is an
> effort of 1/2 hour for each of us if we share the work. I'd like to take
> on the type namespace part.
>> http://trac.openlayers.org/browser/sandbox/bartvde/owsformats
> Thanks for your efforts!
> Andreas.
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
