[OpenLayers-Dev] Docs Refactored to use Sphinx
Christopher Schmidt
crschmidt at metacarta.com
Tue Dec 23 18:56:49 EST 2008
On Tue, Dec 23, 2008 at 04:42:05PM -0700, Tim Schaub wrote:
> Hey-
> Christopher Schmidt wrote:
> > After playing with Sphinx for a couple other reasons, I have decided
> > that not using Sphinx for our documentation builds was a complete
> > mistake, and have changed the OpenLayers build process to use it.
> > What this means:
> > * The URLs or the docs we had have now changed, as has the layout,
> > slightly. I'm sorry for that, but hopefully it will be a one-time
> > change.
> > * The docs can easily be built with Sphinx. Simply:
> > easy_install Sphinx (possibly with sudo)
> > svn co http://svn.openlayers.org/trunk/doc
> > cd doc
> > make html
> > This will create a directory of documentation for you.
> Nice! Thanks for the work on this Chris.
NP. You suggested sphinx the first time around, I should have listened
more strongly, but was concerned about getting "look and feel" right
within the sphinx framework. (This ended up not being too difficult, in
the end.)
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
