[OpenLayers-Dev] Docs Refactored to use Sphinx
Tim Schaub
tschaub at opengeo.org
Tue Dec 23 18:42:05 EST 2008
Hey-
Christopher Schmidt wrote:
> After playing with Sphinx for a couple other reasons, I have decided
> that not using Sphinx for our documentation builds was a complete
> mistake, and have changed the OpenLayers build process to use it.
> What this means:
> * The URLs or the docs we had have now changed, as has the layout,
> slightly. I'm sorry for that, but hopefully it will be a one-time
> change.
> * The docs can easily be built with Sphinx. Simply:
> easy_install Sphinx (possibly with sudo)
> svn co http://svn.openlayers.org/trunk/doc
> cd doc
> make html
> This will create a directory of documentation for you.
Nice! Thanks for the work on this Chris.
Tim
> Information on sphinx is available from:
> http://sphinx.pocoo.org/
> Regards,
More information about the Dev
