[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #926: Google Style Popups
Pierre GIRAUD bluecarto at gmail.com
Thu Feb 7 06:14:16 EST 2008
Please don't forget that Tim Coulter and Roald Ewit also worked on that too.
It would be helpfull for you to also check their work.
I think that Roald code is available in this ticket (or another one)
and tim's code can be found into the topp/nymap sandbox. It's worth
looking at this and maybe have a discussion with them. I would be also
happy to help you and talk about this on IRC when I'm available.
Regards,
Pierre
>   Reporter:  CloudAmber  |       Owner:  euzuro
>       Type:  feature     |      Status:  reopened
>   Priority:  minor       |   Milestone:  2.6 Release
>  Component:  Popup       |     Version:  2.4
> Resolution:              |    Keywords:
>      State:              |
> Comment (by euzuro):
>  Replying to [comment:14 pgiraud]:
>  > Here's a new patch for this ticket.
>  > As proposed, the FramedBubble doesn't inherit from an existing class.
>  Though, it behaves like an AnchoredBubble and offers the same APIMethod
>  and APIProperties. I kept the same namespace. I'm not sure this is a good
>  idea though.
>  > What this code does :
>  >  - resize the bubble based on its content,
>  >  - allow user to define his own bubble decoration by setting a different
>  image and dimensions (see framedPopups.html and click on "change
>  decoration"),
>  >  - shift the map if bubble isn't entirely viewable
>  > What should be easy to add to the code :
>  >  - the animated panning when map is shifted,
>  >  - the animation when the popup is resized
>  > What the code is still missing :
>  >  - a way to handle overflow 'auto' when the content size is too large,
>  >  - the close button creation should rely on a property of the bubble,
>  >  - a well documented procedure on how to create the decoration bubble
>  properties (an image with dimensions is available on the framedPopups.html
>  example page though)
>  Pierre!!!! This is great work. I've got a window to do some OL work, so
>  I'm going to take this excellent patch and I'm going to poke it a bit to
>  see if I can't get it to fit inside the classical (but yes, admittedly,
>  flawed) popup architecture.
>  Give me a day or so and let's see how it advances. Big Big Big thanks for
>  your work on this... you have singlehandedly reeled in the diaspora of the
>  original CloudAmber code. Bravo!
> Ticket URL: <http://trac.openlayers.org/ticket/926#comment:15>
> OpenLayers <http://openlayers.org/>
> A free AJAX map viewer
> Trac mailing list
> Trac at openlayers.org
> http://openlayers.org/mailman/listinfo/trac
More information about the Dev mailing list
