[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #926: Google
Style Popups
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Thu Feb 7 08:07:43 EST 2008
Hi Pierre,
one question, you said in the IRC meeting that the popups size themselves
according to the content.
Is it currently possible to specify a maxWidth and maxHeight for the popups,
and have scrollbars in them if the content exceeds the maximum dimension?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Pierre GIRAUD <bluecarto at gmail.com>
Naar: dev at openlayers.org <dev at openlayers.org>
Onderwerp: Re: [OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #926: Google
Style Popups
Datum: 07/02/08 09:14
> Please don't forget that Tim Coulter and Roald Ewit also worked on that
too.
> It would be helpfull for you to also check their work.
> I think that Roald code is available in this ticket (or another one)
> and tim's code can be found into the topp/nymap sandbox. It's worth
> looking at this and maybe have a discussion with them. I would be also
> happy to help you and talk about this on IRC when I'm available.
> Regards,
> Pierre
> On Feb 7, 2008 7:20 AM, OpenLayers <trac at openlayers.org> wrote:
> > #926: Google Style Popups
> > Reporter: CloudAmber | Owner: euzuro
> > Type: feature | Status: reopened
> > Priority: minor | Milestone: 2.6 Release
> > Component: Popup | Version: 2.4
> > Resolution: | Keywords:
> > State: |
> > Comment (by euzuro):
> > Replying to [comment:14 pgiraud]:
> > > Here's a new patch for this ticket.
> > > As proposed, the FramedBubble doesn't inherit from an existing
class.
> > Though, it behaves like an AnchoredBubble and offers the same
APIMethod
> > and APIProperties. I kept the same namespace. I'm not sure this is a
good
> > idea though.
> > > What this code does :
> > > - resize the bubble based on its content,
> > > - allow user to define his own bubble decoration by setting a
different
> > image and dimensions (see framedPopups.html and click on
"change
> > decoration"),
> > > - shift the map if bubble isn't entirely viewable
> > > What should be easy to add to the code :
> > > - the animated panning when map is shifted,
> > > - the animation when the popup is resized
> > > What the code is still missing :
> > > - a way to handle overflow 'auto' when the content size is too
large,
> > > - the close button creation should rely on a property of the
bubble,
> > > - a well documented procedure on how to create the decoration
bubble
> > properties (an image with dimensions is available on the
framedPopups.html
> > example page though)
> > Pierre!!!! This is great work. I've got a window to do some OL work,
so
> > I'm going to take this excellent patch and I'm going to poke it a
bit to
> > see if I can't get it to fit inside the classical (but yes,
admittedly,
> > flawed) popup architecture.
> > Give me a day or so and let's see how it advances. Big Big Big
thanks for
> > your work on this... you have singlehandedly reeled in the diaspora
of the
> > original CloudAmber code. Bravo!
> > Ticket URL: <http://trac.openlayers.org/ticket/926#comment:15>
> > OpenLayers <http://openlayers.org/>
> > A free AJAX map viewer
> > Trac mailing list
> > Trac at openlayers.org
> > http://openlayers.org/mailman/listinfo/trac
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
