[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #926: Google
Style Popups
Pierre GIRAUD
bluecarto at gmail.com
Thu Feb 7 14:47:44 EST 2008
Actually, you can already specify a min size.
Currently the size of the viewport is a constraint for the max size of
the popup.
We could easily imagine a max size defined by user as well as it is
done for min size.
Though, I don't think this would work with the current code because I
set the overflow to 'hidden' for the content. That way, weird display
issues are avoided but scrollbar won't show.
Regards,
Pierre
On Feb 7, 2008 2:07 PM, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> Hi Pierre,
> one question, you said in the IRC meeting that the popups size themselves
> according to the content.
> Is it currently possible to specify a maxWidth and maxHeight for the popups,
> and have scrollbars in them if the content exceeds the maximum dimension?
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Pierre GIRAUD <bluecarto at gmail.com>
> Naar: dev at openlayers.org <dev at openlayers.org>
> Onderwerp: Re: [OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #926: Google
> Style Popups
> Datum: 07/02/08 09:14
> > Please don't forget that Tim Coulter and Roald Ewit also worked on that
> too.
> > It would be helpfull for you to also check their work.
> > I think that Roald code is available in this ticket (or another one)
> > and tim's code can be found into the topp/nymap sandbox. It's worth
> > looking at this and maybe have a discussion with them. I would be also
> > happy to help you and talk about this on IRC when I'm available.
> > Regards,
> > Pierre
> > On Feb 7, 2008 7:20 AM, OpenLayers <trac at openlayers.org> wrote:
> > > #926: Google Style Popups
> > > Reporter: CloudAmber | Owner: euzuro
> > > Type: feature | Status: reopened
> > > Priority: minor | Milestone: 2.6 Release
> > > Component: Popup | Version: 2.4
> > > Resolution: | Keywords:
> > > State: |
> > > Comment (by euzuro):
> > > Replying to [comment:14 pgiraud]:
> > > > Here's a new patch for this ticket.
> > > > As proposed, the FramedBubble doesn't inherit from an existing
> class.
> > > Though, it behaves like an AnchoredBubble and offers the same
> APIMethod
> > > and APIProperties. I kept the same namespace. I'm not sure this is a
> good
> > > idea though.
> > > > What this code does :
> > > > - resize the bubble based on its content,
> > > > - allow user to define his own bubble decoration by setting a
> different
> > > image and dimensions (see framedPopups.html and click on
> "change
> > > decoration"),
> > > > - shift the map if bubble isn't entirely viewable
> > > > What should be easy to add to the code :
> > > > - the animated panning when map is shifted,
> > > > - the animation when the popup is resized
> > > > What the code is still missing :
> > > > - a way to handle overflow 'auto' when the content size is too
> large,
> > > > - the close button creation should rely on a property of the
> bubble,
> > > > - a well documented procedure on how to create the decoration
> bubble
> > > properties (an image with dimensions is available on the
> framedPopups.html
> > > example page though)
> > > Pierre!!!! This is great work. I've got a window to do some OL work,
> so
> > > I'm going to take this excellent patch and I'm going to poke it a
> bit to
> > > see if I can't get it to fit inside the classical (but yes,
> admittedly,
> > > flawed) popup architecture.
> > > Give me a day or so and let's see how it advances. Big Big Big
> thanks for
> > > your work on this... you have singlehandedly reeled in the diaspora
> of the
> > > original CloudAmber code. Bravo!
> > > Ticket URL: <http://trac.openlayers.org/ticket/926#comment:15>
> > > OpenLayers <http://openlayers.org/>
> > > A free AJAX map viewer
> > > _______________________________________________
> > > Trac mailing list
> > > Trac at openlayers.org
> > > http://openlayers.org/mailman/listinfo/trac
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
More information about the Dev
