[OpenLayers-Dev] OpenLayers and Virtual Earth version 5 +
Christian López Espínola
penyaskito at gmail.com
Mon Jan 7 13:51:44 EST 2008
Hi Paul,
Between VE3 and VE5 the API have changed, and I think that the OL code
has not been adapted to those changes.
You should use Virtual Earth 3 API with OpenLayers, or hack OpenLayers
to work with VE5 (if you do this, please contribute that code to the
project!)
Hope this helps
On Jan 7, 2008 1:58 PM, Paul Huey <huey.paul at gmail.com> wrote:
> Hi All,
> Can anyone help please.
> I am using Virtual Earth version 5 and 6 and have problems utilising
> OpenLayers.
> I can get OpenLayers to work with version 3 and 4 of VE but not in the
> latest versions.
> What happens is that the VE tiles are drawn but I have no control of VE,
> either panning/zooming changing 2D/3D / Running the VE JS functions. etc..
> etc..
> Does anyone have any experience with VE5 + and openlayers and if so any idea
> how to get round my particular problem.
> The problem I have can be easily tested using the VE openlayers html and
> changing the script line from version 3 to 5.
> Many thanks,
> Paul....
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Regards,
More information about the Dev
