[OpenLayers-Dev] Using OpenLayers with ArcGIS Server
Connie Leung
conniehl at gmail.com
Thu Jan 10 16:46:32 EST 2008
I have a website that is based on ArcGIS Server ADF (.net). I would like to
display points stored in sql server on the map. The requirements for the
points are
1) display the point dynamically based on data stored in the db
2) draggable on the map (in order to update the coordinate in db).
3) the point is selectable by a single point of click
4) have a mouse over popup box associate with each point.
I was looking at the openLayers examples and seems like its Vector layer can
do all 4 requirements. My question is does anyone of you have experience in
integrating openlayers with ArcGIS Server? Do you think it is doable? Do you
recommended to overlay openlayers with ArcGIS Server?
I am not a savoy developer, I would be great if anyone can you give me some
pointer where to start.
Thanks for any advice in advance
Connie
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080110/6a91c580/attachment.html
More information about the Dev
