[OpenLayers-Dev] transition sandbox - request for comment
Paul Spencer pspencer at dmsolutions.ca
Tue Jan 15 16:11:38 EST 2008
Eric,
the sandbox is unchanged, you should be able to try it out.
http://dev.openlayers.org/sandbox/pagameba/transition/examples/transition.html
Everything is pretty good except for the animated tiled layer, which
suffers from the problems indicated.
Cheers
Paul
On 15-Jan-08, at 3:00 PM, Eric Lemoine wrote:
> Paul,
> Thanks a lot for this status on your work. This certainly helps move
> forward. Is your sandbox still available to see the thing in action
> before looking at the code?
> Thanks,
> Eric
Cheers,
Paul
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the Dev mailing list
