[OpenLayers-Dev] Using OpenLayers with ArcGIS Server
Connie Leung
conniehl at gmail.com
Fri Jan 18 15:31:43 EST 2008
I am thinking of Method 1. Any idea where to begin?
Thanks,
Connie
On Jan 14, 2008 4:16 PM, Yingqi <anakintang at gmail.com> wrote:
> How do you want integrate exactly?
> (1) still use the web application ArcGIS Server Web ADF generated and have
> merge OL layers into that web application?
> Or
> (2) You just need the services from ArcGIS Server and integrate that as a
> layer in OL?
> If (2) then the short path is to publish your service as a WMS service,
> otherwise you may have to extend OL to deal with ArcGIS Server Web
> Service;
> if (1) I believe it's quite hard if not impossible...
> Thanks,
> http://www.nabble.com/Using-OpenLayers-with-ArcGIS-Server-tp14744724p14814891.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080118/1f28bc90/attachment.html
More information about the Dev
