[OpenLayers-Dev] SelectFeature conflicting with drag-to-zoom rectangle?
Eric Lemoine eric.c2c at gmail.com
Mon Jan 21 00:30:29 EST 2008
On Jan 20, 2008 6:30 PM, John R. Frank <john.frank at metacarta.com> wrote:
> In this example,
> http://www.openlayers.org/dev/examples/boxes-vector.html
> one can cause a zoom rectangle to freeze in place and not zoom by
> attempting to release the zoom rectangle over one of the boxes.
> This problem goes away if the Control.SelectFeature is removed.
> This problem also happens in v2.5 (with toGeometry implemented
> separately).
> Any advice on how to fix it?  The docs for SelectFeature 'hover' say that
> it catches unhover events.  Is there something else to set for catching
> unclick?
> I'm sure this can be fixed in trunk;  is there a work around for v2.5?
I can't reproduce the problem on
<http://www.openlayers.org/dev/examples/boxes-vector.html>. Is it
because Chris has changed the example not to use "hover:true"?
Eric
More information about the Dev mailing list
