[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #1273: Support
reprojection of vector layers
Paul Spencer
pspencer at dmsolutions.ca
Mon Jan 21 09:22:36 EST 2008
On 21-Jan-08, at 8:41 AM, Christopher Schmidt wrote:
> For context, see http://trac.openlayers.org/ticket/1273
>>> r5828 changes the behavior of Layer.GeoRSS by not loading the data
>>> when
>>> the layer is added to the map any more. This breaks the
>>> point-track-markers.html example (#1287). It might break other
>>> applications as well.
>>> I do not see the benefit of this change. I would not consider
>>> loading
>>> the data when adding the layer to the map as a waste, because the
>>> amount
>>> of data to load is the same for every extent (unlike e.g.
>>> Layer.WFS). Or
>>> am I missing something here?
I do see the benefit of the change as Chris explained it. I haven't
looked at why the example broke, but I think it would be worth
investigating to see why. Also, if this change breaks something, then
should there have been a test that caught it? I think so.
Cheers,
Paul
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
More information about the Dev
