[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #1273: Support
reprojection of vector layers
Christopher Schmidt
crschmidt at metacarta.com
Mon Jan 21 10:01:08 EST 2008
On Mon, Jan 21, 2008 at 09:22:36AM -0500, Paul Spencer wrote:
> On 21-Jan-08, at 8:41 AM, Christopher Schmidt wrote:
> >For context, see http://trac.openlayers.org/ticket/1273
> >>>r5828 changes the behavior of Layer.GeoRSS by not loading the data
> >>>when
> >>>the layer is added to the map any more. This breaks the
> >>>point-track-markers.html example (#1287). It might break other
> >>>applications as well.
> >>>I do not see the benefit of this change. I would not consider
> >>>loading
> >>>the data when adding the layer to the map as a waste, because the
> >>>amount
> >>>of data to load is the same for every extent (unlike e.g.
> >>>Layer.WFS). Or
> >>>am I missing something here?
> I do see the benefit of the change as Chris explained it. I haven't
> looked at why the example broke, but I think it would be worth
> investigating to see why. Also, if this change breaks something, then
> should there have been a test that caught it? I think so.
Well, we did have a test that caught it: my modifications neccesary to
the tests indicated quite clearly that there was an API level change
neccesary to make the code work. The fact that it broke other things is
a symptom of that. This is one of the reaosn that I added it to the
release notes as soon as I added it: I was aware that it was an API
change.
The only code that breaks in this case is the example code, and we dno't
test the examples automatically (only manually), so I don't think that
this was an unexpected failure mode.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
